How to use the web server tips (connected/disconnected)?
Using the web server tips into a VI to know when a client is connected or disconnected.
Hello Everyone
I want to use the tips that appear when a remote user gets control of my VI via web server. That way I will be able to trigger some other operations as soon as the user gets in or out my VI. How can I extract the information that contains that (user has or has not control). I hope you can help me.
Regards
Marco Roman
(2,648 Views)
There is a VI method called Remote Panel Client Connections. It returns an array of clusters with connection information and also has a Controller output. If the controller output is -1, no clients are connected.
(2,644 Views)
Thank you for your quick answer
That worked just perfect for me (^^,)
(2,631 Views)
