How to use the front panel and the terminals of a subVI simultaneously
@altenbach wrote:
@Yamaeda wrote:
@altenbachThat's actually what i wrote in my first post, but if you forget to "Set values as default" or initialize that Array it can cause some issues that you won't have with 4 clusters, so i thought i'd let it slip. 🙂
Us graphical programmers are not good with words, so unless I see it on an image, i miss things (still cannot find it ;))
Yes, I mentioned to make the four-element array the default..
Yes, words can be hard sometimes. As is life. 😉
It's what i meant with my "Place those Controls in a Cluster and type-def it, then use an Array of that cluster instead of 4 copies."
Currently i'm on a non LV Project so can't really open and post code. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 21
(432 Views)
