How to use a prologix usb-gpib connector
Hi, I bought a prologix gpib to usb controller. But I don't know how to use it. Is there a driver I can download? Is it compatible with Labview program? Thank you very much.
(2,797 Views)
Give Google a search, it looks like there are a few applicable results.  You  might also want to take a look at this post from the forums.  Goodluck!
Message Edited by jmcbee on 03-27-2009 05:15 PM
(2,789 Views)
And if you find all the posts and look at the information from Prologix, you will find that while it can be used in LabVIEW, it is not compatible with any of the instrument drivers. So, if your intent was to make use of existing drivers, you will find that the money you saved may be erased by the time you spend rewriting code.
(2,785 Views)
