How to use a common place robotic arm in labview
Hi so I am trying to write a program that will use the common place robotic arm to sort blocks into piles when the right logic has been found. But the common place robotic uses a program called CProg to control the movement and program the robotic for mapping. So I want to know if there is a way of using the two together or just using labview to do it.
(2,888 Views)
Hi EJBB,
it would really help when you would supply more information on your "common place robotic arm" and its software…
(2,864 Views)
http://cpr-robots.com/products/mover6.html This is what I am using, but I have no idea how to link that up with labview
(2,861 Views)
Hi EJBB,
just citing from the linked website:
Of course the robot can also be controlled by another software, the CAN protocol is well documented.
Starter Set: The enable an easy start the starter set contains all necessary parts: the robot arm, a stand, a two finger gripper, the mains adapter, USB to CAN adapter and the CPRog software.
So you got the needed USB-2-CAN adapter and a documentation of the protocol…
(2,858 Views)
Would you be able to help me understanding the protocol and how to use it within labVIEW?
(2,825 Views)
Hi EJBB,
I probably would be able to do so - but I don't like to spend my spare time on this…;)
To actually really write a LabVIEW VI to handle the CAN communication I would need to get the robot, the USB stick and a better manual. (And some money for my work…)
- Their user manual describes the CAN messages needed to control the robot arm.
- Their user manual is somewhat vague on describing the message IDs and when to use them. But they offer support by phone and email!
- Their user manual doesn't mention how to communicate with the USB-2-CAN stick…
- Their user manual also describe how to write "batch" files for their CProg tool…
(2,810 Views)
