03-15-2012 11:35 AM
Hi abikutn,
You can search for NI products that meet your needs by searching here. You can narrow down the search based on your constraints.
03-29-2012 05:09 PM - edited 03-29-2012 05:18 PM
Yayyy !!! ...
Finally ANALOG DEVICES have agreed to give me the required drivers for labview to control their evaluation board named HSC EVALC
http://www.analog.com/static/imported-files/eval_boards/265181843HSC_ADC_EVALC.pdf
Now I have to communicate my labview with this EVAL board which is basically a FIFO board.
Please guide me how to start. I can pick up the rest when I get the knack of it eventually.Also I have attached with this message a JPEG to illustrate what I am exacttly upto. Advices please.
Thank you guys
03-29-2012 05:17 PM
Pretty picture but not worth anything in getting your question answered. Since you seem to be the only one with this driver and you have provided 0 details on it, how do expect anyone to answer?
03-29-2012 05:26 PM
Thanks for the immediate reply.
But I am a newbie ... What details exactly are you expecting for ? ... I mean the drivers they provided me has the following attached files.
I think there is somehow a way to control this board with labview using these files. Escpecially when they have given the Direct VI .
Please find the attached files and help me know better.
Thank you.
03-29-2012 05:27 PM
Hi also this file was sent to me.
03-29-2012 05:43 PM
Attaching the files is the sort of detail you could have provided.
With just a brief look, the VIs are interfacing to a couple of DLLs (adidatafunc.dll and FIFOInterface.dll). The installer in your second attachment will probably install one or both but I cannot run it.
Other than that, none of the VIs appear to have any documentation and I don't see anything that tells someone where to start. Try experimenting. Doubt you could do much damage.
03-29-2012 06:02 PM
yeah thanks! ... They havent provided me with any documentation either. However I will start experimenting.
Is there any steps or methods of how I have to go about using these files to communicate to the hardware ?
I mean any tutorials from NI.
I shall start experimenting right away. Just need the start.
Thank you
