02-27-2012 07:08 PM
Hi to everyone,
This question may have occuerd earlier but I have never got a clear and direct answer for this.
ISSUE : I have a High Speed DAQ module DC1371A evaluation board from Linear technology [ http://cds.linear.com/docs/Demo%20Board%20Manual/dc1371A.pdf ].
Question: Since DAQ/DAQmx allows only Ni devices to be interfaced, how can I configure this module to work with labview.This module has a software Pscope [ http://www.linear.com/designtools/software/ . How do I proceed.
Thank you guys,
Abhi
Labview 11
02-27-2012 10:45 PM
You would need to see if they provide some sort of DLL, or ActiveX interface, or .NET interface that you can call from LabVIEW. Contact Linear Tech and ask them what libraries or API they have to talk to the board from programming languages.
02-27-2012 10:56 PM
Ok. what if they dont have any ... At the worse case is there any other way to communicate with the board/ module ?
02-28-2012 05:17 AM
02-28-2012 08:13 AM
Have you tried asking first?
02-29-2012 10:55 AM
Yes I asked. They asked me which application I will be using so that thy can see if thy can get me the drivers. The lady took my email adress too ... I hope she helps me out... I am waiting with patience ...
02-29-2012 12:36 PM
02-29-2012 12:44 PM
Ok will call her now ... Exactly why shud I wait ... U r right ... Thanks ...
02-29-2012 02:57 PM
Your board is actually a Demonstration Circuit (DC) used to evaluate ADCs that you might be interested in buying from them. It's not a product that is likely to be supported with drivers and other conveniences. My guess is that you're going to have problems getting any type of driver that will let you press it into service as a DAQ module.
Can't hurt to ask though... Good Luck!
03-14-2012 11:31 AM
I asked her and she told Linear Technology wont provide any kinda drivers to communicate with LV. If needed I have to use their PSCOPE program that displays the signals etc.
This is bad.
Can you guys please suggest any other DAQ module with ADC ( 14 bit and 250 msps) and a DSP board with it to process the data, Both of which I can communicate with LV without any hassle.
I am tired of waiting for other companies to offer some way to communicate with LV. or Please advice HOW TO GO ABT SETTING UP A HIGH SPEED ADC AND DAQ MODULE. I think its better I start from scratch.
Thank you
