How to use a C# dll in Labview?
How can I use a C# dll in Labview 8.2? With the "Import Shared Library" Wizzard I need the header file which I don't have. Is there another way
to use such .dll to import the functions created in C#?
Thanks in advance
                              NorickSmiley Happy
(3,919 Views)
Norick,
C# != C++
So, you won't call C#-code with a Call Library Function Node.
You have to use the .NET-functions, namely constructor ~, property ~ and invoke node and the close reference function. You can find these in the Connectivity >> .NET palette.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,914 Views)
Norbert
is there a application note how to create step by step such class librarys with the .net functionallity?
            Norick
(3,896 Views)
Norick,
afaik there is no tool which provides you the possibility to create something like an instrument driver for .NET assemblies.
Maybe we should take a look into terminology:
- Instrument driver: This is a set of functionality, which provides the user with an easy to use API for a special instrument. Very often, the driver itself is written in C/C++ and provided as a DLL.
- "Import Shared Library" Wizard: This wizard enables the user to create an own API for any C/C++ DLL (or compatible) for LabVIEW. This wizard requires the information on all exported functions; this info is contained in the header file. The result of the wizard is a set of VIs containing one Call Library Function Node each for each exported function.
- .NET assembly (extension .exe OR .dll): This can be compared to ActiveX. So the way to program with .NET is similar to ActiveX. Maybe you want to take a look into the examples of LabVIEW regarding .NET...
- Global Assembly Cache (GAC): All assemblies contained here are registered in the system. Every application can easily work with assemblies contained here.
- Private assemblies: This would be the way to work with .NET assemblies which are built on your own. You have to select the .DLL-file itself and make sure that the file can always be found in the same (relative)folder of your application.
hope this helps,
Norbert
Message Edited by Norbert B on 02-21-2007 02:16 AM
Norbert
Expert: Geometry
(3,890 Views)
