How to use User-Events and Queues between Executables
Hi ,
thanks for this idea. But I don´t unterstand it.
"The user event in LabVIEW essentially has 3 subcomponents in it that you would need to ensure get copied over TCP.
1. The reference (data type + pointer to a memory address where events can be sent).
2. The registrations
3. The data sent with each event"
How can I implement this. The reference is only valid in one executable. There is a possibility to do this by vi-server, but all my tries didn`t work
Message 11 of 17
(1,462 Views)
avogadro5, thanks a lot, I´ll check this.
Message 12 of 17
(1,462 Views)
I checked this and I think, thats nearly that I´ve found in an very old post, but without an example... so thanks a lot.
But 🙂 :  You wrote in the client-vi --> "reference from remote program: we can't use it in this app". Thats the reason, why, if I made an executable from the client-vi, it doesn´t work...
Or did I made something wrong. Is it nescassary to load it from the executable-path?
But the solution is not far away for me...yeah
Message 13 of 17
(1,422 Views)
Accepted by topic author Tanchris
If you built the client into an exe, then I expect what failed is the node that opens a VI in the remote app from disk:
This path is not actually on disk in a normal build, it's a "virtual" path inside the built client exe and can't be opened from outside the client exe. You can work around this using the build spec to have the client VI in the support folder instead of inside the exe:
Which results in the VI being placed in the data folder.
Message 14 of 17
(1,413 Views)
in the LV7 / LV8 time I used to share action engines between 2 LabVIEW built apps, both running on separate Windows PXIs
I took me a while to dig the lava forum thread about this, if it may help...
https://lavag.org/topic/7732-how-to-shared-a-fgv-between-2-lvprojs/
Epictetus
Antoine Chalons
Message 15 of 17
(1,395 Views)
that works fine...thanks.
Is this VI actually part of the executable or not? Or how do I call it so that it is not part of the exe?
Message 16 of 17
(1,274 Views)
The VI is not part of either EXE because I configured the build spec to put it on disk in the support folder instead of embedded inside the exe. This page has info about that setting under "Destination" https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/resource/framework/providers/builds/appbui...
If you run that build spec you can see the VI is in the data folder next to the exe file.
Message 17 of 17
(1,257 Views)
