How to use Derivative x(t) PtbyPT , I'm not sure, when i use.
when i use this function i'm not sure that i connect its correct or not, could you help me for checking?
Smiley Sad
but i saw  that the output of integral x(t)  PtbyPT  is very large, it's correct or not?
(2,638 Views)
Hi
You can used the function in a seperate VI and check the output for a known value. When I am running your Vi i am not able to recreate the problem which you are saying.
very large means what?
Just try using the derivative vi seperately and you will know whether you are getting the results are right
Regards
(2,622 Views)
Please review the example VIs included with the following article to get an idea of the proper usage of Derivative Point by point VI.
How do I take a derivative in LabVIEW ?
Ankita
(2,619 Views)
