How to use DSSS or FHSS sequencing methods in LabVIEW using modulation pallete
I already learned your sample code.
I have little problem here, is it possible to recover the symbol without demodulation?
Because I see your code, and there is no demodulation block
Thank you
Message 11 of 17
(1,507 Views)
Hi wicak,
Could you expand on what you want out of the demodulation? There are several more examples in the NI Example finder under Toolkits and Modules>Modulation>Simulation. I have attached a screenshot of the MT FSK Mod-Demod.vi.
Andrew.N
Applications Engineer
Message 12 of 17
(1,478 Views)
For example, under modulation toolkit pallete, I can find demodulation pallete,
There are demodulation PSK/FSK, etc
But, I didn't see it in you screenshot,,
Or, the demodulate FSK, in your screen shot can explained by several steps showed in your screenshot? (match filtering -> compute ideal symbol timing ->decimate -> map -> etc)
Message 13 of 17
(1,470 Views)
I noticed that the spreading code being used is 1 code..
What if I want to use several spreading codes?
For instance, I have a table contains 5 PN codes, that I used for spreading,,
How does the receiver de-spread it?
Message 14 of 17
(1,453 Views)
Hi can you please put FHSS modulation model in Labview? Thank you!
Message 15 of 17
(1,414 Views)
my problem is to setup syncronism in the system. I added sdr Tx and Rx to this model with configured triggering and made user-defined message, This message is properly decoded only cyclically. What measures can you advice to solve this problem with timing?
Message 16 of 17
(1,246 Views)
Hello William,
the block diagrams in (niWLAN 80211bg Generation.vi ‏28 KB) are password protected, would you send me this?
regards
Salvador
Message 17 of 17
(714 Views)
