How to use ActiveX to make Adobe Reader 9 Save as Text...
I am trying to make a program that you can select a .pdf file and it will open it in Adobe Reader 9 and use the "Save as Text..." feature. I have seen VIs that can open .pdf files, but none that can save them as text files. Does anyone know how to do this?
Thanks for any help
(3,047 Views)
I am not familiar with the active x calls that are associated with Acrobat, but you can use keyboard keys to save as text. Have a look at this example that uses Labview to control a media player. This can also be applied to Acrobat.
http://decibel.ni.com/content/docs/DOC-15310
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(3,024 Views)
I am familiar with the ActiveX controls, but I cannot get the structure set up correctly in order to use the Perform Menu Task method. My guess is that is where the Save as Text... process would be under.
(3,019 Views)
I am a bit confused with the methods you are trying to call, can you post some sample code for some clarification?
Did you give the keyboard method a try?
Eric
Eric Liauw
(2,997 Views)
