How to update fields in word
Just, I am trying to add the loops to your work but I can not change the methods in the section class to footers and in the "sections" what should be "index" is set at "item" too. Actually I can not modify or select any of the methods...
Message 11 of 18
(1,628 Views)
Sounds like you didn't use the snippet properly.  It should convert all of the items in the picture to actual VIs and property nodes.
http://www.ni.com/tutorial/9330/en/
If that is not the issue, then I have to ask, do you have Word installed on your Labview computer?
aputman
Message 12 of 18
(1,621 Views)
I think I used it properly. I just dragged it into a Blank vi and the elements are paste... But the invoke nodes and property nodes have just the method you selected not the others...
And I have Word installed on my computer.
Message 13 of 18
(1,614 Views)
Are you on a Mac?  I don't know if ActiveX is available on a Mac since it is a Windows technology.
aputman
Message 14 of 18
(1,609 Views)
No on Windows 10... I am using Firefox so I tried to use my desktop as an intermediary but I have the same issue...
I also tried with IE but it's the same...
Message 15 of 18
(1,605 Views)
I'm not sure what to tell you at this point.  I would ask you to share your VI but i am on 2012 and probably won't be able to open it.  I pasted the snippet into a VI and it works on my machine.
2015 is the first version to officially support Windows 10.  If you are running an earlier version, there may be issues there with Windows 10 and ActiveX.
aputman
Message 16 of 18
(1,582 Views)
Hi tried this morning on another computer with Labview 2014 and not 2015 (and with Windows 7 and not 10) and it works perfectly...
Message 17 of 18
(1,550 Views)
Here is the VI...
Works with me thank you.
Message 18 of 18
(1,533 Views)
