How to update fields in word
Hi everybody,
Is there a way to update all the fields as explained here (Update a cross-reference from one page to another)
https://support.office.com/en-us/article/Create-or-update-a-cross-reference-aa35c606-34e8-4c64-b6eb-...
in order to update cross-references linked to bookmarks in a word template before closing it while appending some texts and pictures ?
I struggle to find a solution.
Cheers,
Message 1 of 18
(6,046 Views)
Are you trying to do this thru Labview?  Or is this a Word question?  Bottom of the article says this applies to Word for Mac 2011.  Does this apply to your use case?
aputman
Message 2 of 18
(6,025 Views)
I am trying to do this through Labview. Actually I am just looking for a way to update/refresh the entire word (fields, cross-reference etc) before closing it. I do not know if it feasible using a Active X command or something else....
Message 3 of 18
(6,013 Views)
Can you do this update routine in the software successfully (without Labview)?  If so, record a macro of your actions and use the macro code to determine the ActiveX objects that are needed to do it externally.
aputman
Message 4 of 18
(6,002 Views)
Is it possible to do a Ctrl+A and F9 with Labview in a word ?
Or to do this Macro
1
2
3
4
5
6
7
8
9
10
11
12
13
14
Dim J As Integer
Dim K As Integer
If ActiveDocument.Sections.Count > 2 Then
   For J = 3 To ActiveDocument.Sections.Count
      For K = 1 To ActiveDocument.Sections(J).Headers.Count
         ActiveDocument.Sections(J).Headers(K).Range.Fields.Update
      Next K
      For K = 1 To ActiveDocument.Sections(J).Footers.Count
         ActiveDocument.Sections(J).Footers(K).Range.Fields.Update
      Next K
   Next J
End If
with ActiveX
Or to do a print preview of the word (with the option updates fields selected in the options of Word) and then add some modification before saving and closing the documents ???
I am new with Labview and I really do not know how to do this...
Message 5 of 18
(5,985 Views)
Accepted by topic author Neercs
This is just a start.  I don't have the For Loops from your macro but you can see how to get access to the necessary ActiveX objects.
aputman
Message 6 of 18
(5,979 Views)
Thank you very much and sorry again but in which library do you all this class ? I just manage to find Fields-Update....
Message 7 of 18
(5,969 Views)
I use the Report Generation toolkit as a jumping off point.  There is a VI there (2nd in the picture) that returns ActiveX references.  The picture I attached is a snippet.  Drag it to your desktop and then onto a block diagram and if you have the Report toolkit, everything will be added automatically to your VI.
aputman
Message 8 of 18
(5,963 Views)
Wow, I didn't know anything about this snippet ^^. I will save a lot of time now ^^. Thank you.
Message 9 of 18
(5,951 Views)
If one of my responses sufficiently answers your question, please mark it as the solution so others that come along with a similar question can see how you solved it.
aputman
Message 10 of 18
(5,939 Views)
