How to turn on and off leds
I have a Boolean Control Push Button, and 3 Boolean LED indicators.  The push button's mechanical action is "switch until released."  What I want to do is push the button and turn on LED 1.  When I push the button again, I want LED 1 to turn off, and LED 2 to turn on.  When I push the button a third time, I want LED 2 to turn off, and LED 3 to turn on.  When I push a button the 4th time I want LED 3 to turn off, and LED 1 to turn back on.  I don't know how to do this.  Any help would be greatly appreciated.  Thanks.
(3,780 Views)
There are many ways to do this. One possible solution is attached (LabVIEW 7.0).
(you don't say what should happen if you click a 5th time ;))
Also, can you explain why your button should be "switch until released"? This is not a very popular setting and rarely appropriate.
(3,772 Views)
I do not have labview 7.0.....Can you tell me the most easy way to do this.....I would really appreciate it....Thanks
(3,768 Views)
Altenbach,
I downloaded the evaluation version of 8 to open up your .vi you made.  I then created that same code in 6.1 and it worked.  Thanks brother.  I appreciate your help.
(3,761 Views)
@leroy27336 wrote:
Altenbach,
Is your problem solved men ??
if it is not I well tell you the solution.
First : I have defined yellow led as pin 6, green led as pin 5 , red led as pin 3, button as 4
I am working at arduino uno so let's begin
I will first define : int sensorvalue =digitalRead(4)
you should define a variable like saying : int variable = 0 for recording changes
then you should increase the amount of this variable every time the button is pressed like saying
if(sensor value == HIGH)
{ variable = variable + 1 // Increase the amount of the variable
Serial.println(variable);  // record the variable
delay(100);
// Light the first Led (yellow led)
if(variable>=0 &&variable<=50)
{ analogWrite(yellow_led,255);
analogWrite(red_led,0);
analogWrite(green_led,0);
// Light the second led (green led)
if (variable>50 && variable<=100)
analogWrite(yellow_led,0);
analogWrite(green_led,255);
// Light the third led (red led)
if (variable>100 && variable<150)
analogWrite(red_led,255);
// returning the variable to 0
if(variable==150)
{variable=0;}
I will download the code and make sure you download the last version of  IDE 1.8.5
 I hope you understand.
and I hope this was helpful.
MOHAMAD
(3,030 Views)
Hi there ! Sorry they don't let me send you the code
(3,029 Views)
