How to transform 32-bit FLOAT number to 16-bit UNSIGNED
Hi there,
I am trying to write 32-bit single precision number to two 16-bit unsigned modbus regsiters. Any ideas how could that be done?
thanks in advance!
(6,144 Views)
How much precision do you need, and how do you want to use the value later?
GCentral
(6,140 Views)
Accepted by zde92
Hallo zde,
maybe this is an inspiration to you:
(6,134 Views)
I got this far, but yours is much nicer. I didn't realise before looking into this how miserable single-precision is...
GCentral
(6,128 Views)
For now, I don't have specific requirement for precision. I'am trying to do the modbus master/slave simulator. The SGL value will be written in input register of slave, then read with Read from input registers function on master. Since the modbus functions accepts the U16 format, the conversion is needed.
(6,113 Views)
Hi there, I tried something similar using type cast to transform to U32 and the used Split Number. But probably, I would need to create the opposite conversion on master where I read the values from register?
(6,107 Views)
Hi zde,
So you get the same result using more functions!? 😄
Yes, when you want to "simulate" this master too…
(6,099 Views)
