11-10-2020 08:47 AM
Hey
Thanks for that code, it helped me a lot. I'm new to Labview and was wondering how I can write the averaged signal into a text or excel file (whichever is easier)?
Thanks!
11-10-2020 08:54 AM
Hi Poly…,
Use any of those file functions!
Start with CSV files aka delimited text files aka "spreadsheet files"…
I'm new to Labview
Did you note that "Training resources" section in the header of this LabVIEW board?
Did you explore the example VIs found in the example finder?
11-10-2020 09:07 AM
Hi GerdW
thanks for your answer.
The problem is that this is not quite working.
This is the code I'm using and it will only write one measurement into my excel file. However, I would like to have one column on date, time and value.
All the best
Annabell
11-10-2020 09:22 AM - edited 11-10-2020 09:28 AM
Hi Annabelle,
The problem is that this is not quite working. This is the code I'm using and it will only write one measurement into my excel file. However, I would like to have one column on date, time and value.
The code is doing exactly what you have programmed to do: "write one sample when the VI finishes"!
There is no code to write any timestamps and no code to write more than one sample.
I also suggested to start with plain text file functions instead of ExpressVIs and "Excel files"…
Hints:
As long as the AutoCleanup tool improves your code (aka make it more readable) your coding style is bad…
You really should take those "Training resources": you don't need to combine autoindexing in a FOR loop with ArraySize to determine the number of iterations…
There also is a SumArray function! And there is a Mean function…
The DAQAssistent gives you a waveform hidden in the DDT wire: that's a special LabVIEW datatype! It's so special it also contains the timestamp information you are looking for…
11-10-2020 09:31 AM
Thanks for not being helpful at all but rather criticise all the things I've done so far. So I'll go back to googling.
11-10-2020 09:59 AM - edited 11-10-2020 10:01 AM
Hi Annabelle,
You also aren't helpful: attaching just images of code does not allow us to debug your code with LabVIEW. We cannot edit images with LabVIEW and so I cannot provide changes to your code as VI. And because of that I just hinted on all those things you need to improve in your VI - on your own as you didn't provide that VI so far!
And I named several "LabVIEW things" with the exact name used in LabVIEW so that you should be able to look them up in the LabVIEW help to actually learn them…
