How to time a segment of code
I've got a case statement inside a while loop, and I need to know how much time it takes to run (in ms)
I tried using :"Tick Count," but both the tick count before and after the case statement are giving the same time, even though the one after the case is in its own case statement box.
I'm sure there's an easy way to do this, and someone with infinite wisdom will disclose it to me 🙂
(3,550 Views)
Accepted by topic author bobholmgren
Here are three ways mentioned.
I think this one is the coolest:
One thing to notice is that 'Tick count' has a resolution of 16 ms on most OS's.
Ton
My LabVIEW Ideas
(3,536 Views)
I created a little function that starts a timer and reads the elapsed time. Start it before yout loop and put the read outside, with a line inside the loop so it will not start before the loop is finished. In LabVIEW 2009.
(3,534 Views)
Ton
How exactly do I go about doing this?
(3,530 Views)
I figured it out
(3,526 Views)
@bobholmgren wrote:
I figured it out
or maybe not, I don't see a pulldown menu on the right. I'm in Labview 7.1
(3,515 Views)
(3,509 Views)
