09-04-2020 07:09 AM
Hmm... I'm seeing something different than that on 2017. I can't get the string "Main Application Instance" no matter what I put where or what's open. I either get the the name of the last project I clicked on if one or more projects is open, or Not a Refnum and therefore error 1055 if no project is open.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
09-04-2020 07:12 AM - edited 09-04-2020 07:32 AM
wiebe@CARYA wrote:How about this (even simpler):
That is what I was about to suggest, I think this will work for the OP.
EDIT: Clear the error coming out of the property node or you get this:
09-04-2020 10:20 AM
Thanks for the help!
I marked Wiebe's post as the solution, but I will will give Redhawk an honorable mention for clearing the error.
I was able to use the snippet to get the code. But it took a few minutes to figure out that the scripting property nodes are inside the regular property nodes so I could recreate it myself. I thought all the scripting functions would all be in the VI Scripting palette.
Thanks again.
