How to take only the positive section of a waveform using Labview 2009
I would like to take only the positive section of my waveform and discard the negative section. I would also want to calcualte the RMS value and put it in some sort of accumulator during each scan. Does any one have any ideas?
Edward
Message 1 of 16
(6,560 Views)
Use the Get Waveform Components to get the Y array.  Wire it to a For Loop with indexing enabled.  Test each data point for >=0.  If true, pass it to a build array function.  If false, just pass the shift register contents straight through.  Rebuild the waveform using the new Y array.
18697i637B36B564FBAFE3
For RMS, look in the palette Signal Processing - Waveform Measurements - Cycle Average and RMS
- tbob
Inventor of the WORM Global
Message 2 of 16
(6,553 Views)
I will try it and see how it works.
Edward
Message 3 of 16
(6,549 Views)
Ok, It works, but I would rather keep the time stamp the same. In other words, if you took a piece of paper and place over the negative section of the sine wave graph, then the remaining waveform is exactly what I would want to reproduce think the way it is set up right now is that it filterer the positive but compresses the data points and leaves no time in between. Is possible to use limits?
Edward
Message 4 of 16
(6,514 Views)
Like this:
18799iCECBC2FD77447DA2
VI is attached in LV2009.
- tbob
Message 5 of 16
(6,509 Views)
Now you are asking for something different. Instead of discarding, you want to replace all negative values with 0. The same code can be used with a minor modification in the false case.
Message 6 of 16
(6,506 Views)
This should work for my application.
Edward
Message 7 of 16
(6,501 Views)
Why not put the whole array through In Range and Coerce from 0 to Inf?
Message 8 of 16
(6,488 Views)
I tested it and it works great.
Edward
Message 9 of 16
(6,460 Views)
Smart thinking RF!
- tbob
Message 10 of 16
(6,450 Views)
