How to take an average every 26 samples in an array of 219 elements?
Hello to every one,
Well the problem i have is that i am having an array of 219 elements and every 26 elements i want to take an average.Can please someone suggest a code solution for that?
(2,121 Views)
Accepted by gtathatos
Hi gstathatos,
here's a suggestion:
(2,115 Views)
Asuming you want the average of the 26 sample sets you need to wire the Length in Gerds example also.
/Y
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
(2,108 Views)
Gerd,
while your suggestion is really good (scalable, well written), you are missing imho one wire: The length of each "chunk" should most probable be 26!
@gstathatos:
Another question which comes to my mind is:
Gerds suggestion chunks the array , so you will get 219/26 = 8 chunks. Each chunk should most probable suffix to the the previous one without having overlapping. Please verify this.
The other option would be to have a "moving average".
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,106 Views)
A slightly modified version of GredW's code.
(I always like to play with array :))
(2,100 Views)
Hi Gerd,
Your suggestion code work as i expected and many thakns for that.
(2,098 Views)
Hi to all,
yes, I forgot to wire the "Length" input of the ArraySubset function. But this was noticed easily...
@P Anand:
Using DeleteFromArray is forcing shuffling of the array content. Using ArraySubset should be more memory-efficient (and probably faster for big arrays).
(2,086 Views)
