05-13-2011 05:18 PM
I have added two while loops with different timing values (execution: one fast and one slow) as shown. I have been able to control both while loops at the same time using local variable as shown in the VI.
What i am unable to achieve is to synchronize both while loops in way that the execution rate of one doesnt effect the other.
Please see the attached VI
05-13-2011 05:25 PM
One while loop is inside the other while loop, creating a data depedency. The outer loop cannot proceed to the next iteration until everything in it, including the inner while loop has completed.
If the two loops should be completely independent, place them side-by-side.
If you just want certain things to happen at a slower rate (e.g. every 10th iteration), use a single while loop and a case structure that bypasses part of the code until [i] is an even multiple of some number.
05-13-2011 05:47 PM
as you might have noticed by running the VI that both my while loops are executed in parallel. That means there is no data dependancy since while loops are not waiting for the other to finish execution. Is there a way that my inner while loop timer value does not effect the main while loop timer value.
Thanks for the reply
05-13-2011 05:59 PM - edited 05-13-2011 06:00 PM
Of course there is a data dependency!
(Sorry I did not inspect your loop termination conditions in details.)
The inner loop only spins once and stops immediately so the outer loop can proceed. It is as if the inner loop werent even there.
Both of your time delays start executing in parallel with every new iteration of the outer loop, so only the longer one determines the total loop rate.
Please explain in simple words how you want the two loops to spin.
05-13-2011 06:10 PM
In simple words, if i run my vi in the fornt panel, my random plot (Red Plot) is also represented in waveform chart (Red Plot) but the execution rate is way different. Since my random plot is executing 0.005 seconds based on timer delay 2 value
I would like to see this red plot in Waveform Chart and co-oping with the main Time Delay which is at slower rate (0.050).
05-13-2011 06:22 PM - edited 05-13-2011 06:23 PM
I don't have the PID toolkit, so I cannot run your VI.
Both charts update once per iteration of the big loop (i.e. every 50ms). The one on the left only looks faster because the x-axis is much more zoomed in. The inner delay makes no difference.
