How to synchronize PXI-4472 input with PXI-6115 output?
How to synchronize 4472 with 6115?Could you give me an example programs or some advices? I have searched at ni.com,but I can't find this kind support.Thank you!
(2,178 Views)
You may look at this Knowledge Base record:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ae63551cd4c4b24886256be4004f4242?OpenDocument
It does not mention 6115 (S Series DAQ). But 4472 can be synchronized with E Series DAQ.
(2,178 Views)
The KnowledgeBase listed above is correct. The main point to consider is that the DSA cannot except external sources, so it will have to be the "master" and the S series board will have to sync to its scan clock. The NI DSA devices are programmed using NI DAQ function calls and there are many shipping examples in LabVIEW or CVI that synchronize two boards together. Most of these examples use a RTSI to route the clocks, but the PXI backplane can be used in the same manner.
Best Regards,
Jeremy R.
NI - Applications Engineer
(2,178 Views)
