How to synchronize FPGA and RT?
Hi all,
I am using crio 9076 with followinf modules: 9234 and 9263. I need to synchronize FPGA and RT working at same frequency which is about 2000 kHz. I am using FIFO as communcation method between FPGA and RT. Is that possible? And how it is possible? What method should I use?
Message 1 of 10
(3,659 Views)
I presume you mean either 2000 Hz or 2 kHz...... if you really want 2000 kHz (2 MHz) then I'll let others answer.... Smiley Very Happy
Message 2 of 10
(3,643 Views)
Sorry I meant 2000 Hz. Do you have any solution?
Message 3 of 10
(3,639 Views)
In our RT Application, we use a read timer for the FIFO read together with whether items are still left in the FIFO or not to essentially run off a timer to keep both RT and FPGA synchronised.
Message 4 of 10
(3,636 Views)
I appreciate that my post helped, but I'm busy with my own workload.... If you ask specific questions, I'm sure people in the forum will be more than willing to help.
>clarification< Response to Private Message
Message 5 of 10
(3,621 Views)
Is it possible to get more on the application?
Do you need to lock phases of input and output data?
In general, I would to get the FPGA to do all the timing/sync and let the RT collect and manage things.  Is this possible in your case?
ALE Consultants
Message 6 of 10
(3,613 Views)
Well that is all what I try. FPGA works as hardware/ software and RT is place where I do calculation. The case is as following: I have input and output modules and I run the FPGA for 2000Hz. The input modules works well. Howerver I need RT working as fast as FPGA because I am creating the controller in RT, which is closed loop, which mean it is using the data coming from FPGA therefore it should works at same rate...
Message 7 of 10
(3,608 Views)
Can the algorithm be put on the FPGA?
On RT, are you using a timed loop?
Have you reviewed http://www.ni.com/compactriodevguide/?
ALE Consultants
Message 8 of 10
(3,605 Views)
In PFGA I am using While loop and in RT timed loop. I have red this guide few time Smiley Embarassed . Still can not solve the problem..
Message 9 of 10
(3,601 Views)
ALE Consultants
Message 10 of 10
(3,597 Views)
