How to switch from voltage device to current device
Hello.  I have an existing LabView program that needs some updating and I'm not quite sure how to do this.
I have a water tank that I measure the conductivity with using a Hanna Instruments conductivity probe with a 0-5V output.   The problem is the probe broke and Hanna doesn't make them any more.  In fact, I've had to switch to an Okton K=10 probe that has a 0-20mA output which will be read with a NI 9208 DAQ.
I expected that I would be able to reconfigure the DAQ assist to accomidate my new device, but I can't seem to find how the existing program is aquiring the 0-5V signal, so I don't know how to change it.
The existing program is receiving the 0-5V signal through a NI-6009 DAQ via the subVI called "Aquire Conductivity Data Loop".  I am attaching that VI here.  Can someone help me figure out how to change from the old conductivity probe to the new probe?
(3,841 Views)
I'm wondering if an undergraduate EE (or maybe a clever high school student who knows Ohm's Law) can give you a clue ...
(3,832 Views)
Please take a look on this information: http://digital.ni.com/public.nsf/allkb/143D1830D99CD40C86257D69007EB302
Its goig to be pretty much the same as with your device.
Regards
(3,770 Views)
5V / 20mA = 250 Ohms.  So you will want a 250 Ohm resistor to sink the current and then measure the voltage drop across it.  That will give you a 1:1 equivalent to what you were already measuring and you do not have to change any software.
(3,745 Views)
So Crossrulz,
Are you an undergraduate EE, or a clever high school student? Smiley Wink
(3,728 Views)
RavensFan wrote:
So Crossrulz,
Formerly a clever high school student and formerly an undergraduate EE.  Does that count?
(3,716 Views)
