How to store information( voltage and current limit) about all three channels in the same memory address when writing a labview program for Agilent E3631A triple output power supply
I'm writing a labview program for Agilent E3631A triple output power supply. Manually I can store information (voltage and current limit) on all the three channels at the same  memory address.(memory address 1)  But when writing the program I cannot figure out how to do that since I can select only 1 channel at a time and if I try to store information about the second channel next time on the memory address 1, it overwrites the one I stored before. I guess that's not how the vis are designed for this. Can somebody help me please.
Thank you
(2,625 Views)
It would be more helpful if you posted the code that you are having problems with.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,611 Views)
