How to split Numbers (U32 to U8)
how can i split a number into its Byte-values (U8)? I found the "Split Number"-thing in labview. Do i have to use this twice for U32? (first U32-> 2x U16 and then U16 -> 2xU8).
Or is there also a faster /more elegant way to do this?
Thanks for help
(8,048 Views)
Accepted by topic author OnlyOne
You can just use the Type Cast function to convert to an array of U8.
(8,042 Views)
I was kind of surprised that this worked reasonably well.  Just typecasting to an array of U8.
* dang, I'm too slow. *
(8,040 Views)
Thanks for the help.
Is there also something easy for the other direction?
(8,008 Views)
Ok, forget my last question. This works in the same way with a typecast...
(8,001 Views)
