01-09-2014 06:55 AM
hello,
i tried with your suggestions, but still i am getting same error.
Is this the same suggestion you asked me to do which I have attached in Attachment or any thing else?
thank you very much for your time and help.
01-09-2014 08:00 AM
01-10-2014 02:46 AM - edited 01-10-2014 02:58 AM
Thank you very much for your kindly help And time.
As you suggested some change for vi, that I did And its work fine means no any error I am getting.
But I am not getting continues Image, could you please explain me your second point.
And what changes I need to do in order to get continues images or video.
In attachment 1 there is screen shot of vi during operation that I am not getting video properly.
In attachment 2 there is screen shot of block diagram.vi.
In attachment 3 there is screen shot in which i made some changes in my vi in that I am obtaining output directly from the IMAQ cast image, but then i am able to get live video but not continueous detection of object.
Thank you very much for your help.
01-10-2014 02:57 AM
01-10-2014 03:01 AM
Thank you very much.
I got your point, I will reply you after doing changes according to your suggestion and let you know.
Thank you very much once again.
01-10-2014 04:27 AM
now its working fine and detecting color also.
is there any way to detect perticulat object to kinect.
please give me any suggestion.
thank you very much once again for your help.
01-10-2014 04:34 AM
01-10-2014 05:16 AM
Thank you very much for reply.
Yah the same thing, like pattern matching.
In my case I want to detect some particular pattern, its detect the pattern but the thing is when light intensity is changed then its not working properly.
Means there is no accuracy, how should I solve this problem.
Thank you very much once again for your help and time.
01-10-2014 05:23 AM - edited 01-10-2014 05:28 AM
-Which method of pattern matching technique you are using?
-Gradient method is more resistant to lighting variations as NI claims.
Ref-
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/pattern_matching_techniques/
01-10-2014 05:34 AM
I am following the Target tracking.vi form the example of labview and I did change according to that.
thank you very much once again.
