How to simulate right mouse click in LabVIEW
I am writing some code in LabVIEW to record the activities of the mouse such as moving, left mouse click and right mouse click.  I am able to reproduce the moving, dragging and left mouse click., but the right mouse click.  May anyone show me how to simulate a RIGHT mouse click in LabVIEW?  Thank you very much.
Son
(5,951 Views)
Just like the left click, but with other values for the parameters. You can see an example here (it's in the timeout case, if I remember correctly) - http://forums.ni.com/t5/LabVIEW/No-menu-on-double-click-with-the-right-button/m-p/2278166#M719994
___________________
Try to take over the world!
(5,935 Views)
I looked at the example and this example works the opposite way of what I am trying to do.  The example using Event Structure to detect mouse DOWN or UP, but what I want is to issue a RIGHT click.
(5,926 Views)
Accepted by topic author rgbspectrumtimeout
Did you look in the timeout case of the event structure?
___________________
(5,919 Views)
I am writing some code to automatically take a screenshot and save it to a bitmap file.  It works fine in the development environment but it doesn't work (the file is created, but no image) once i make it as an executable.  Please help me out if you know the solution.
Thank you very much
Son
(5,914 Views)
Son,
Please keep your requests to either a single Forum post, or just to your service request that you have already created and have been using. Thank you.
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(5,882 Views)
