04-03-2014 04:23 AM
Could someone help me in the setup and configuration of NI OPC server to OMRON PLC (CJ2H model) using FINS Ethernet communication protocol? I already read some materials available in the web but it uses a different PLC and communication protocol. The OPC server is installed in my laptop and I'm using Windows 8 as my OS. I used a cross over RJ45 LAN cable and connected to the ETN21 module of the PLC. I was able to confirmed the communication of my laptop and PLC by pinging the ip address of the ETN21. I also tried to configure the OPC server based on the documents I just read online. I created a channel, device and tag to the OPC server. By the way, I just need to read the data from the tag I created. Can someone also tell me how to monitor the data on the tag? I hope that you could help me. Thank you in advance.
04-04-2014 09:36 AM
Good day,
Try following the instructions on the driver’s help, take a look at the attach picture. It should be a good starting point. After the PLC is configured you can use this tutorial (Connect LabVIEW to Any PLC Using OPC » http://www.ni.com/white-paper/7450/en/) for a guide on how to monitor the tags.
I hope this helps
