How to set text to be transparent to clicks?
Originating Need
I have the desire to have an LED-button on the Front Panel (FP) which is used as a Button. I would like to add white-text over the top of it as a label (e.g. 'Skip' or 'Run')
Current Issue
When a text Label is added on the FP over the top of the LED ('Reorder->Move To Front') you can't click on the LED through the text 😞
Question
Is there a way to make the full region of the LED clickable here, specifically the region behind the white-text label?
If there is, that would be sooooo rad 😉
-Justin
justinmreina@gmail.com
(4,000 Views)
You can have Boolean Text shown. Right-click the LED and go to Visible Items > Boolean Text
FYI, careful with having your email address in your signature. There are bots that scour forums like this for email addresses to sell.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,995 Views)
you can programically change "text" and "color" or make it "transparent" with property node
(3,976 Views)
Accepted by topic author Justin_Reina
I think OP didn't know that boolean text was an option. He was having problems with a text label he made separately and put over the button and it blocked clicking.
In the below FP boolean, I can click the "OFF" just fine to control the button, but the other text blocks:
Cheers
(3,963 Views)
Hi James  & apok,
 Thank you!!! I compiled your responses into a tabbed example VI, for others who may someday stumble upon this now silly question.
Thanks!
*I couldn't attach the VI for some reason... it was rejected on 'file-format'. So I just zipped it up and it magically posted 😉
(3,893 Views)
