01-09-2017 03:44 PM
If I create a reference to an indicator, I can set every property I need to. I'm trying to duplicate what I did on a single boolean indicator on 20 of them. I used This VI, to Pane, to Controls[] The references aren't useful at all. I tried casting them to more specific class (Boolean) but that doesn't work either. How can I get an array of references that will work the same as ones I create by right clicking?
01-09-2017 03:58 PM
You probably have not cast it to a class that was specific enough. Which properties are you trying to set?
Attach a VI with the controls and what you have so far.
01-09-2017 04:29 PM
Turn on scripting (if you havent already) and traverse the FP for all Booleans then test for them being not indicators
