How to set name of X and Y in Graph?
Highlighted
what is the property name to set the name of the x and y at the border of a graph?
The good souding property XScale.Name.Label.text is not working (or is doing something different 🙂
best regards
TM
(244 Views)
Highlighted
For me the "X Scale.Name Label.Text" works as expected: it changes the scale label…
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(227 Views)
Highlighted
Perhaps you should share some code and/or give a better explanation of what you were expecting. My suspicion is that the Xscale.Name Label.text is working properly but your code is not giving it the value that you think it is giving - but I'm only guessing since I have not seen the code.
(218 Views)
Highlighted
Attached a screenshot with marked text that i want to change.
(210 Views)
Highlighted
Accepted by topic author OnlyOne
If you want to change the Y axis label then you should change Yscale, not Xscale.
(192 Views)
Highlighted
head->table
(189 Views)
Highlighted
Hi One,
@OnlyOne wrote:
head->table
Lesson learned: always provide code right from the beginning!
(146 Views)
