How to set LabVIEW to not start with an empty VI - with keyword in the INI?
Good day!
I wonder that this seems to be unquestioned. LV always comes up with an empty VI unless I start it by double-clicking on a specific VI.
Can this be changed? It's a bit annoying to always close the two empty VI windows. In the Options there is nothing, as far as I see it.
My thinking is that a keyword in the INI could do that, but which one. I searched if there is sort of a reference for the INI keywords, but to no avail.
(872 Views)
Hi MaSta,
@MaSta wrote:
LV always comes up with an empty VI …
You only need to close the frontpanel, then the block diagram is also closed… 😄
Simple test:
  1. quit LabVIEW if open
  2. create a backup of your LabVIEW.ini
  3. delete the LabVIEW.ini
  4. start LabVIEW
What happens?
(867 Views)
Yes, yes, but closing the FP is already too much. 😁
INI: Nice, but only works once.
(858 Views)
Hi MaSta,
So you deleted the LabVIEW.ini and upon starting LabVIEW you get the usual GettingStartedWindow (GSW)?
And after quitting and starting LabVIEW the next time the GSW does not show, but you get an empty VI again?
What is the content of the LabVIEW.ini after the first run?
(847 Views)
Accepted by topic author MaSta
Found it! Now it works.
I think this is due to a bad translation to German. There is an option "Startfenster überspringen". I didn't connect the main window of LV as the Startfenster. A starting window or screen is usually the splash screen you see when LV starts and which, as I realize now, LV would still show.
Doh!
(835 Views)
Hi MaSta,
So "Getting Started Window" is translated to "Startfenster": not that bad I guess… 🙂
(826 Views)
Getting Started isn't better. Let's say it's an "overall bad term". For me it's a main window, much clearer. The term "Getting started" is not to be found anywhere in that window.
(820 Views)
