07-25-2005 09:27 AM
07-25-2005 09:36 AM
07-25-2005 09:40 AM
07-25-2005 09:50 AM
07-25-2005 10:08 AM
07-25-2005 10:16 AM
07-25-2005 10:35 AM
Whenever you place a new string into the table, also place it in a shift register. Thus you can get the last entered item directly from the shift register, no need to extract it from the table again later.
The "Index Array" function only gives you the first element IF you don't wire the index. Wire the desired index and you should be able to get any element you want. If it is a 1D array get the last element by wiring "array size - 1" to the index. If it is a 2D array, it'll be a bit more complex.
The attached example (LabVIEW 7.0) shows a few possibilities.
Modify as needed. 🙂
07-26-2005 02:00 PM
