How to search for a string phrase containing a changing number
Hello.  I've been digging through Scan From String to figure out a way to essentially search for a string/phrase that contains a possibly changing number.  So an example...
Words words words words words Lum1naryKnight words words word words.  But it's possible the phrase is instead Lum2naryKnight.
Any suggestions/help here would be greatly appreciated.
Message 1 of 10
(794 Views)
Try Lum[1-2]naryKnight
Also read the help for Match Regular Expression or Match Pattern for more expression examples
=== Engineer Ambiguously ===
Message 2 of 10
(784 Views)
Check the help for Special Characters for Match Regular Expression
Message 3 of 10
(776 Views)
Accepted by LuminaryKnight
Or Lum[\d*]naryKnight to handle any integer.
* old punch line: Now you have two problems.
Jim
Message 4 of 10
(755 Views)
"possible changing number" is too vague to offer a solution. Let's assume from the sparse examples that "number" is a positive integer (no decimal point, scientific format, minus sign, etc.), but you have not defined what the possible range is (single digit? multiple digits?, etc.). Is the word delimited always a <space> (not tab, linefeed, etc.)
Are e.g. all the following valid inputs?
  • "Words words words words words Lum1naryKnight words words word words"
  • "Words words words words words lum1naryknight words words word words"
  • "Words words words words words Lum1naryKnight. words words word words"
  • "Words words words words words Lum1naryKnight, words words word words"
  • "Words words words words words Lum0naryKnight words words word words"
  • "Words words words words words Lum123456789naryKnight words words word words"
  • "Words words words words words LumnaryKnight words words word words"
What do you want to get out of it? The word with the changing number? The numerical value?
How long is the entire words string? Can the "special word" occur zero or multiple times? Can other words contain embedded integers to find? Is the "special" word case sensitive?
so. many. questions.
Message 5 of 10
(736 Views)
Let's say every option is viable except the last one, LumnaryKnight.
Let's also say that of those variable "words", "Knight" and "Lum" and "nary" could be hidden or scattered amongst them.  Which is why it's imperative to find specifically, Lum#naryKnight
To keep things dynamic, I'd prefer to program for multidigit.  But, we can limit the scope to "no decimal point."
Message 6 of 10
(722 Views)
Lum[0-9]+naryKnight
Message 7 of 10
(717 Views)
Jim
Message 8 of 10
(712 Views)
Well now I don't know whose answer to accept. But... thank you!  Extremely helpful.  Solved my issue.
Message 9 of 10
(696 Views)
You can mark multiple solutions.  But I would say jcarmody's post is the most complete solution.
GCentral
Message 10 of 10
(687 Views)
