How to save Nibbles (4bit-pieces)?
I have a Hex String which I would like to write to file. Each hex
charakter should be represented by a nibble.
I convert the hex characters to decimal characters, then I use
"decimal string to numbers" vi and change the format to U8.
The problem is, if I look at the written file with a hex-editor, each
nibble is filled up to 8 bit with zeros.
For example if I save a few hex characters "03F01042" to file and open
it with the hex-editor it would look like "00030F0001000402" (each
character added a prefix-zero).
I thought I would have to write to file with nibbles not with U8 but I
didn't found any vi that could do so.
Anybody an idea how to overcome this little problem?
Thanks in advance.
(5,059 Views)
Hi Toni,
An easy solution would be to write 2 hex characters at the time to the file...
Benoit
(5,059 Views)
I just solved a similar problem the hard way.
There was an instrument which communicated over serial (visa), and I wanted
to deal with the nibbles. I did:
- string to U8 byte array
- indexed the byte array for each U8
- converted U8 to boolean array
- get desired nibble as a subset of the boolean array
- build-array (concatenate inputs) with each high and low nibble
- build an array of U8
- convert U8 array to string
Something like that should work for you..... If you need any help email me
at joey@quantumsignal.com
-joey
"Toni Lindner" wrote in message
news:998e6cbb.0208090532.61174ed7@posting.google.com...
> Hi,
> I conv
> Thanks in advance.
(5,059 Views)
Thanks BigBen and Joey for your help.
I did it the hard way as Joey described and tried to post this little vi called "Hex_save" to the community.
Toni
(5,059 Views)
Hi All,
There is a more efficient way to build an U8 out of 2 nibbles in U8's and that
is to use the Logical Shift functions in the 'Advanced\Data Manipulation'
Palette.
Instead of explaining, how to do it, I have attached an example VI.
Tim
> -joey
> > Hi,
> > Thanks in advance.
(5,059 Views)
