10-15-2019 09:08 AM
10-15-2019 11:18 AM
Did you read the pretty thorough Documentation (a PDF, a Word Document, a readme.txt file)?
I notice (from the Documentation) that these files and documentation are pretty old (the Documentation refers to LabVIEW 2012 and 2013, and a VI opened at random was saved in LabVIEW 2015).
I don't know if the "5646r hardware is needed" in your Subject line is a Question or a Statement, but the documentation definitely refers to this hardware, and I suspect it is, indeed, needed.
10-16-2019 07:09 AM
10-23-2019 02:25 AM
no one can answer this?
10-23-2019 03:42 AM
Hi chen,
@dearchen wrote:
i try compile the fpga but false
Answer to what? (Maybe you should be a little bit more specific?)
Which problems do you encounter?
Which software do you use?
