08-16-2011 06:16 AM
I am trying to run an application through web publishing tool which is having 5 screens. I could able to see the very first screen successfully but as i navigate to the other from my application, new screen is not displaying. I also tried the same by including the url while building exe also but not working.
Please guide me.
Subbu
Solved! Go to Solution.
08-16-2011 06:43 AM
08-16-2011 07:11 AM
Hi gita,
Thanks for reply. But if i use remote panel, does that transfer the control to the user? i want it to be only for monitoring purpose...
08-16-2011 01:08 PM
HI,
If you are going to develop a web application, you should be very clear and careful about this.
On Web the pops and your popup subvis will not work properly, You have to develop your application on Tab control. Your complete solution should be in a single packet.
If you want to give the access to different-different 5 users you can easily provide it. All users can monitor and control your application easily on web.
Its upto you, you can define the number of users to access the web application.
If you publish your application on local IP this will work only in your local network but if you publish it on your public IP this will work as a web application like Google, gmail, yahoo.....
Thanks and Regards
Himanshu Goyal
08-17-2011 12:15 AM
Hi Goyal,
Yes i want it to be in local ip only and am able to give access to diffrerent users but were not able to navigate. Also thanks for suggesting tabs so tht my application lies in one vi
subbu
08-17-2011 12:36 AM - last edited on 03-27-2024 02:49 PM by Content Cleaner
Hi Subbu,
If you use connect to remote panel option, you can give access to control only if required else they can only monitor. And "yes" with this option the pop-ups will not appear on the client PC's and few issues see here for more details https://www.ni.com/docs/en-US/bundle/labview/page/errors-when-connecting-to-remote-front-panels.html. hence you can use tabs as Goyal said or you can use customised pop-ups in your application.
08-17-2011 04:02 AM
HI Gita
Thanks a lot for the link which is more informative. So its better to go with tabs and customised pop ups...
Thanks a lot...
