How to reverse the reading of the ultrasonic sensor value
Hello Good Morning All,
I have a problem with my project about ultrasonic sensor,
My problem i can't reserve the reading of ultrasonic,
How to reserve the reading of ultrasonic sensor?
Can u help me, see attach mail for detail
Thank You,
Stewkidz
(3,912 Views)
If what you mean only reverse in the display, just use vertical slider, change the upper and bottom label.
Kudos and Marked as Solution == Thanks
(3,889 Views)
Hi
check sensor connection first if that's not solved try this.
it  will reverse--> esrever 0-45-->45-0 the actual value
bp
(3,874 Views)
MR bharathp10
Can u give me .vi format
Stewkidz
(3,863 Views)
Accepted by topic author StewKidz
(3,861 Views)
Thank sir
(3,835 Views)
