How to response the value change of slide bar only after mouse released
Yes, this method is what I am using now.
thanks.
Message 11 of 13
(1,024 Views)
There is a special situation you need to handle with a slider and the mouse up event.
If you mouse down, you can slide the slider back and forth even if you move the mouse off the slider.  When you mouse up, the event structure will not detect a mouse up event for the slider because the mouse is no longer over the slider when that happens.  So you could wind up changing the value and never detect the change by way of the mouse up event.
Message 12 of 13
(1,019 Views)
Yes
Could I check if mouse down?
If the mouse down can be check, i think i can filter the value change event.
I will not update my device if the slide bar value changed and mouse down.
Message 13 of 13
(1,012 Views)
