How to reset one or more boolean switches based on another boolean switch.
@altenbach wrote:
You still don't have a top level loop. Are you using continuous run?
You still don't have an event structure, so a signaling value property seems incorrect. Just use a local.
The disabled property is in both cases, so a single instance belongs outside the case.
Are you using continuous run? - Yes, as previously said but only until I get the principle correct. Then it will be applied to my master VI.
Use a Local - Okay.
The disabled property is in both cases, so a single instance belongs outside the case. - It does make things easier to read.
Based on the fact that this is just a building block, I think my attempt was not far wrong. Your solution is neater 😊
Thank you for all your help.
Best regards
Mark.
Message 11 of 11
(38 Views)
