03-11-2011 08:50 AM
Use read/write FPGA control function right click it pops up a menu that shows all control/indicators on the FPGA program panel. Is there a way to change the order the control/indicators show in the pop up menu?
Thanks a lot!
Tom
03-11-2011 09:23 AM
I am not sure but try "Set Tabbing order..." from the Edit menu of the FPGA front panel.
01-12-2015 02:05 AM
I'm working on a big FPGA project, I have a lot of controls on front panel and I think it's frustrating to reorder tabs manually everytime I have a change in the fp.
Is there any automatic reorder in alphabetical order or similar?
01-12-2015 08:15 AM
There is a little known feature for grouping FPGA controls using grouping and dot notation.
http://forums.ni.com/t5/LabVIEW/Group-FPGA-Controls-With-Dot-Naming/m-p/2772208#M816334
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-12-2015 10:24 AM
Well this could help me to handle huge quantity of fp controls..many thanks!
I have to use dynamic mode references but I see that I can switch the mode off when I have to program the IO node, then I switch on dynamic mode when I have to run the VI..a little tricky but fine!
MZ
01-12-2015 12:13 PM
Yeah not sure why this doesn't work in dynamic mode. Maybe that is why NI doesn't mention this feature more. Maybe that should be the idea exchange item, to support this in all FPGA modes.
