12-01-2022 05:42 AM
Hi everyone,
i am measuring the current value on a motherboard with my Agilent 34410A.
As you can see in the image, it seems to be present a noise on the signal.
Any suggestion for remove this noise with a filter?
12-01-2022 06:13 AM
Hi Mario,
Why do you think it's noise?
Which current on which motherboard are you trying to measure?
12-01-2022 07:46 AM
Hi GerdW and thanks for the reply,
I am measuring the current on a motherboard designed by a friend of mine.
I applied the ammeter between the transformer and the motherboard in order to know the current draw.
I made a small diagram:
This noise seems to be natural oscillations of the ammeter that I even see without any load applied.
How can I remove it?
12-01-2022 08:27 AM
Hi Mario,
When the ammeter shows such "noise" then you should do a (re)calibration!
12-01-2022 08:51 AM
Any Variant in signal (Noise) in measurement, usually requires recalibration of an ammeter.
Should be the first step.
12-05-2022 03:57 AM
Good morning,
the recalibration of the ammeter is unfortunately blocked by a unique 12-digit code from the manufacturer. It should be attached to the purchase documentation but since more than a year has passed I can't find it. I will contact the manufacturer for information.
In the meantime, thank you all.
