03-28-2006 08:31 AM - edited 03-28-2006 08:31 AM
@chilly charly wrote:
When painted in "transparent" color, the "shadow" disappear. Transparent is the only color that has an effect of the 3D appearance, obtained using the front panel background color, slightly lighter and darker.
Well... I'll be a flying monkey... CC is right again..
The way to get a clear 3D decorative frame is to select transparent "T" (in the upper right corner of the paint tool) for BOTH the fore & back grounds...
WOW... now.. why would someone do that?? but heck... it can be done...
Ah... the wonderful & unlimited world of LabView...
Thanks CC!
EDITED PORTION >>>>>>
And yes... I've already thought of reasons why you would want to do this.. Hummm ... clever. 😄
Message Edited by JoeLabView on 03-28-2006 09:34 AM
03-28-2006 08:33 AM
03-28-2006 09:08 AM
I finally got it! Thank You!!
Aitortxo, there is one thing you are missing. When you click on the border, you must right-click and the pointer must be exactly over the border. Then it will bring up the color palate. Now you can use the space key to toggle between the split colors in the bottom left corner of the color palate. Make the color on the left transparent and the border will vanish.
pdaks
03-28-2006 09:18 AM
03-29-2006 07:32 AM - edited 03-29-2006 07:32 AM
Previous postinf deleted due to its inappropriate wording.
Ben
Message Edited by Ben on 03-29-2006 07:34 AM
03-29-2006 08:05 AM
03-29-2006 08:34 AM
And thanks Shane for sharing..
I won't feel as bad for not knowing this trick.
Well done CC!
Tu ne cesses de m'impressionner 😉
03-29-2006 11:14 AM
Aahum !.. Thanks for the star avalanche, but are you sure that was worth the work ? Just clicking with the paint brush on an object to change its color doesn't seems a very challenging operation... 🙂
Now, if somebody could find a way to do it programmatically, that's another story ! 😉
03-29-2006 12:47 PM
03-29-2006 01:12 PM
Look!
Another chance to introduce even more chaos into the contellation of stars!
NO, must resist, must not push button.... (should be read as if James Tiberius Kirk was talking).
Ben
