You need to unregister the ActiveX:
The command to manually register or unregister an ActiveX component is:
C:\WINDOWS\SYSTEM\REGSVR32 filename
or
C:\WINDOWS\SYSTEM\REGSVR32 /u filename
Then delete filename.ocx or .dll
"Phil"
wrote in message
news:3a085351@newsgroups.ni.com...
> Currently in my "Select ActiveX Object" window (from right clicking on an
> ActiveX container ->insert ActiveX object) I have several garbage controls
> that i made to test some code and block diagrams
> As such, several copies of the same ActiveX control are in the menu
> Does anyone know how to remove these controls from the menu?
> (and how did I added them in the first place?)
> Also if anyone can point me in the direction of some good resources
regarding
> A
ctiveX objects and Labview, it would be greatly appreciated
