How to reference a subVI in Application (c.f Development mode)?
Highlighted
Am trying to create a pop up screen from my Main VI. So I need to reference to it using VI server from the Main and also close the SubVI when the user choses to close it.
In development mode I can use: current VI's path for the subVI or I can use current VI's path for the main and then build/strip path to get the subvi or I can use Application Directory.
Question is how will this be done when the application is built--- as in the application the path of the subvi does not exist anymore? Is it automatically located?
(383 Views)
Highlighted
hello,
the exe will start the main vi as startup vi. if you had mentioned in startup vi while building.
Depends on how you build exe
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
(367 Views)
Highlighted
Hi rajiv,
You can also use a static VI reference…
The path of the subVI typically stays the same inside the executable (since LV8 or so)…
CLAD expired, using LV2011SP1 + LV2017 (+LV2019 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
(355 Views)
Highlighted
That is my preferred method unless dynamic instanciation is required.
Ben
(347 Views)
Highlighted
Accepted by rajiv85
I do this using a sub-Panel in the Main VI.  When I want to run (and see the Front Panel of) a sub-VI, I use a Static VI Reference to the sub-VI and wire it to an Insert VI Method for the sub-Panel.  This not only starts the sub-VI running as a parallel asynchronous loop, it also provides access to controls and indicators on its Front Panel which act in the context of the sub-VI.
The same code works both in Development Mode and when built into an Executable (the Static VI Reference works wonders in this way).
(286 Views)
Piling it on...
 Another bonus of the static reference is that it includes the target VI in the hierarchy of the caller. This means no surprises when we try to invoke the VI and find out it was broken since it was not open and some code change broke it.
Ben
(281 Views)
Highlighted
Thank you all for the responses!! Smiley HappySmiley Wink
(245 Views)
