How to realize Soft SPS in parallel to DAQ ?
Problem: To control Robots in prallel with a running DAQ.
Suggestion: Create a Soft Control (Profi Bus or alike) and an DAQ Software as a LabVIEW Applikation
Question: Is this possible to realize or not ?
(2,407 Views)
If your question is whether you can control something at the same time you are doing data acquisition, the answer is: Absolutely!
The bigger question is what the control interface looks like. Are you talking a serial connection, some sort of fieldbus? If you need to use something like Profibus, the trick will be finding a controller that you can talk to with LV. Check with NI.
Do you have any more details of the application?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,407 Views)
