How to read from .csv file in this case
Hi Matipa,
would you mind to attach your current state of the VI?
@Matipa wrote:
everything looks good but now i have no my measurements nex to the graph
Then wire the waveform array to that "measurement analysis" ExpressVI…
Message 21 of 26
(1,252 Views)
I attached my current program.
Still can't show my saved waveform on the screen of front panel...
Message 22 of 26
(1,247 Views)
Hi Matipa,
@Matipa wrote:
 everything looks good but now i have no my measurements nex to the graph:
Those values are calculate by the ExpressVI outside the loops in your VI. Before you had connected it to the array of waveforms, but now you connected it to the scalar waveform from DAQmxRead - even though I had shown it differently in my image…
Message 23 of 26
(1,219 Views)
Yes I did it becuase when I wired it like You told there was no measurements... You can see it now in my attached program, but when i wired it to DAQ signal it was possible to see the measurements...
Message 24 of 26
(1,196 Views)
Hi Matipa,
as you did not set any data to default before saving your VI I cannot check why that ExpressVI doesn't provide the expected data…
Message 25 of 26
(1,190 Views)
Is now possible to see the reason?
Message 26 of 26
(1,169 Views)
