How to read cRIO hostname or serial number locally
I haven't done much work with cRIO and decided to ask for help.  ;o)
I know about the VIs that allow access to this information from a connected Windows machine, however, I want retrieve and display this information on remote panels.  But, I'm having trouble determining how to read the cRIO hostname or serial number in software running on the cRIO?
Thanks for assistance.
James
LabVIEW 5.0 seems so long ago...
(3,482 Views)
Accepted by James@Home
This might help.
(3,481 Views)
This is a broken link. Can any one give a working link?
(3,234 Views)
Check out the System Configuration API.  There's an example called "Show All Hardware" in the Example Finder that gives an idea of how you could do this.  Just make sure the target is set to "localhost" if it's going to be running on the cRIO.
Cody A.
(3,204 Views)
