How to read a "read from spreadsheet file" not when I run the VI??
Hello again, as you know, when you use "read from spreadsheet file" when you run the VI, if there's nothing at the path port, a window which asks which file do you want to open pop... The fact is: How can that window pop only when I want and not before?? thank you
Carlos Ignacio Sarmiento
Electronic Engineer
(Ciudad Madero Technological Institute)
Laboratory of Bioelectronics, Biohospital Engineering Departament
National Institute of Neurology and Neurosurgery "Manuel Velasco Suárez" (Mexico City)
(2,770 Views)
'Read from Spreadsheet' need a file path to read from. You image shows a blank file name so the 'Read' vi prompts for one.
Click the button attached to the the path control to select the desired file BEFORE running the VI and no prompt will appear when the VI runs.
(2,761 Views)
Yeah, I know it, it is the only way I get the program running well, but I'm planning to convert it after to an executable file, how can I solve this problem before do it?
Electronic Engineer
(2,737 Views)
maybe a for or if loop, I don't know...
Electronic Engineer
(2,736 Views)
don't worry, I solved it, it needed just an event case hehe thank you anyway
Electronic Engineer
(2,735 Views)
